VeriStand
Feed custom device output back to multifunction control in VS workspace...
Is it possible to have a custom device output channel wired back to a custom multifunction control such that the control can read the output channel's value?
(4,079 Views)
Hi swbpnole
I think there sould definitely be a way to accomplish this, however, I've never gone through the procedure of doing so. Let me do some testing and I'll give you an update tomorrow on this
WenR
(4,052 Views)
swbpnole
I think I missread your quesiton yesterday, so what you want to do is to bind one of the channels of the Custom Device to a Custom Workspace Control, is this correct? Is there any reason why this channel cannot be selected from the "Select channel" window when you configure the control in the workspace? This options should be given to you when you place the control in the workspace ( if you used the tutorial below to build the control)
Creating Custom Workspace Objects for NI VeriStand
WenR
(4,040 Views)
