VeriStand
Error -307703 occurred at SE Dialogs.lvlib when importing dllinto veristand2021
it seems I had post a question at a wrong place,here is my problem:
below is more information:
1) I installed Matlab 2021a first
2)I downloaded MingW64 complier and placed it at D:\D:\mingw64,here is its version information by cmd windows:
3)I added the system variable path such as below:
4) I installed veristand 2021R3,its information is as below:
5)I installed VeriStandModelGenerationSupport.mltbx, by double clicking it within matlab window
6)I Made I simple model as below:
its code generate parameters are:
7)I bulid a virtual linux RT machine, followed the instruction(I secceed):
https://dokuwiki.hampel-soft.com/kb/ni-rt/linuxrt/linuxrt-on-vmware
8)after all ,I build that model ,it seems everything is OK.
9)at last ,I tried to import it into Veristand,settings of Veristand is like below:
10)but it tells me they are incompatible,CRY CRY CRY, I obeyed all the rules,but failed.
Message 1 of 1
(390 Views)
