VeriStand
XNET Cyclic Frame Faulting: Can I fault for a period of time and then return to nominal afterwards?
I'm trying to fault a frame which is nominally sent at 100Hz by sending it at 1000Hz for period of time. I thought the way that this would work is that the Faulted transmission time would be used while my trigger is active and then the nominal value would be used when my trigger was inactive. When attempting to use this, it seems like the faulted transmission time is used and then it never returns back to nominal when I reset the trigger. Is there a different way that I should be running this test in VeriStand?
VeriStand 2021R3.
(433 Views)
Nevermind. I just realized that Transmit Time can be accessed directly. I just need to reset transmit time back to nominal and then trigger again to fault back to the nominal case. Hope that helps somebody else out in the future.
(428 Views)
