VeriStand
Error -307737 : VeriStand target(s) does not have data sharing support
Hi everyone,
Our service is pretty new to the VeriStand environment and me also. We are trying to make the transition from LabVIEW to VeriStand 2019 R3 but we are facing a main issue while trying to use the Stimulus Profile Editor, I would appreciate some help from you ! 🙂
The issue is happening when we add a cRIO (cRIO-9054) AI or CAN channel reference (either from DAQ Chassis/ either from Scan Engine/Ethercat add-on) in a Real Time Sequence, this same sequence is called within a Stimulus Profile, and then  the error -307737 occur, whereas we can read and write these channels in the VeriStand UI screen...
I was actually thinking that Ethercat would resolve this issue, but it did not.
I saw about reflective internet, but it looks like an older solution, reflective memory devices that may also be a solution.
Thanks for your advices, I can give you further information if needed.
(2,020 Views)
Hello, up please
(1,991 Views)
This error occurs when deploying a real-time sequence that uses channels or aliases associated with another target. To solve this issue use a Real-Time Sequence Group Step and a Real-Time Sequence for each Target.
https://zone.ni.com/reference/en-XX/help/372846L-01/veristand/rts_group_step/
(1,936 Views)
