VeriStand
System Explorer Vertical Pane Adjustment
Reference the solution in the link below to allow resizing of the System Explorer window:
https://forums.ni.com/t5/NI-VeriStand/System-Explorer-window-is-not-resizable/td-p/3703014?profile.l...
This is very helpful and would only be better if it was possible to adjust the vertical pane [red arrow] horizontally to make the right side of the window wider.  I was not able to find .ini syntax to adjust this.
Any recommendations?
Message 1 of 1
(1,673 Views)
