VeriStand
Event associated with setting model parameter
When simulation model parameters are set using one of the methods in http://zone.ni.com/reference/en-XX/help/372846M-01/veristand/model_param_import/ , is there some way to generate an event, and the model respond to that event?
Thank you.
Siva
(3,167 Views)
Hi Siva,
What type of event are you wanting to do, and how are you wanting to do this? In theory you could utilize the VeriStand API in LabVIEW to poll the values of the parameters and code some functionality for when those change. I am not aware currently of an automatic way though to trigger an event from importing the parameter values.
Madison T
(3,137 Views)
Hi Madison,
My simulation model has a state machine, and I would like for it do some action when there is a value change in a parameter.
I guess I could do the polling similar to what you suggested in the model itself. But if I were to not do it in the model (may be to save on execution time), would I have to write a custom workspace control that would poll the value of a parameter, and generate an event? How would this even be communicated to the model?
Thank you.
Siva
(3,133 Views)
Hi Siva,
What type of action are you wanting to trigger? There could potentially be different methods of doing this, such as procedures, depending on what action you are looking for.
Madison T
(3,119 Views)
