VeriStand
Run project automatically at windows startup
Hello.
Is there any option to deploy a veristand project at windows star-up? I want to start a project where I have disabled a lot of windows options to use it as operator stage. I'm thinking about generating a simple VI to do that and generate an executable file which runs at windows start-up... But maybe there is a simplest solution.
Thanks in advance.
BR.
Miguel.
(4,094 Views)
I don't want a DenverCoder009 moment.  There is an option to do this on an RT target, settable from the system explorer.
If you want to do this on your Windows machine, you can make a VI (or run some other code calling the VeriStand APIs) to deploy the system definition.
(2,602 Views)
