VeriStand
FPGA-IRQ in VeriStand Custom FPGA VI?!
I have built a custom FPGA VI to use in VeriStand. This FPGA VI contains following IRQ:
Now I have also a LabVIEW-VI with FPGA code which I want to use in VeriStand. I have changed it to use it as a custom device, so I removed all the FPGA code and replaced it with indicators and controls so that I can map the Custom Device to the custom FPGA in VeriStand.
But there is still the FPGA-IRQ and I do not know what to do with these two nodes:
How can I use these node in my Custom Device VI or in general in VeriStand?
Thanks for your help.
HScho
(6,838 Views)
Hi HScho,
Thanks for posting on NI forum.
Can you tell us a bit more about the purpose of your custom device?
there is a native support of FPGA board in NI VeriStand, you may want to read this :
Creating FPGA-Based I/O Personalities for NI VeriStand
Have a great sunday,
Flo
(6,829 Views)
I have already used a custom FPGA-Based I/O Personality. The FPGA program generates the PWM, reads the Encoder and filter and replicate signals.
I have attached the LabVIEW VI's which I wanted to use as Custom Device. So you think I should add the program code of this VI's to the Custom FPGA-Based I/O Personality?
HScho
(6,822 Views)
At the moment I am not using a custom device. I created again a model of the "Motor Velocity Control PIDv2 (RT).vi" and imported it in VeriStand. It seems to me that there is problem with the "RCP sbRIO DC Motor.vi".
If i change the motor voltage inside the subVI the value of PWM Duty Cycle changes. But the value is not present in the main Motor Velocity Control VI.
If I put a probe I can see the value going to the indicator, but the indicator of PWM Duty Cycle is always showing 0....
I have no idea why this happens!
(6,803 Views)
Accepted by HScho
So finally I have found a solution:
I disabled all of the IRQ stuff. The main problem was that the model I wanted to use in VeriStand was inside a While Loop. I had to remove the While-Loop because VeriStand itself is the loop.
HScho
(6,781 Views)
