05-01-2022 08:57 AM
I have a labview program that gathers data sent via WiFi from a microcontroller. The data sent is the following: Temperature (ºC), Pressure (Pa), Humidity (%), Altitude (m), Consumption (A) and Time (s).
Right now it just gathers the sent string from the embedded and separates it into 6 different number indicators (DBL). The number indicators only show the last data sent and what i want is to see in a separate graph every variable in function of time (Y=variable, X=time).
How do I do this? Thanks in advance.
05-03-2022 09:20 AM
Hi, this does not seem like a VeriStand question.
Recommend you repost in the LabVIEW forums:
https://forums.ni.com/t5/LabVIEW/bd-p/170
