VeriStand
How do I programmatically close a VeriStand NIVSPRJ file?
Hello all,
I'm using the command line commands (https://www.ni.com/docs/en-US/bundle/veristand/page/run-operations-command-line-interface.html) and VeriStand 2020 R5 and can successfully open an NIVSPRJ, deploy/connect/undeploy/etc.  I use the command "openProject" to open the project, but after undeploying, the project stays open in the Idle state.  How do I close it?  Do I have to kill the process from the command line or something like that, or is there a more elegant programmatic approach I'm not seeing in the documentation?
David
(2,406 Views)
I'm getting around this currently by calling taskkill /IM "VeriStand.exe" with System Exec.vi, but this seems less than ideal.
(2,358 Views)
