VeriStand
Run Stimulus Profile VI
Hello together,
i want to run a Veristand Stimulus Profile in the simplest way, using the Run Stimulus Profile VI.
Attached you can find my VI and the error code i recieve. Where could be the problem?
(2,602 Views)
Hi mihamm,
Well, I guess the problem is "missing information": no attachment, no error code…
(2,572 Views)
Sorry, now you should see the error code. 😉
(2,565 Views)
Hallo mihamm,
did you read the error description in the error dialog?
Did you follow the suggested solutions?
(I don't use Veristand and I could move your post into the Veristand board, if you you agree…)
(2,555 Views)
Yes, of course, you can move the post to the Veristand board.
I thought this was more of an issue with Labview.
Yes, I read the error description and followed the suggested solutions.
(2,551 Views)
