VeriStand
How to change CAN-FD "Sample Point" using VeriStand .NET API?
Trying to change 'Sample Point' under CAN Port Spec using .NET API. Don't see any options.
Any suggestion?
(850 Views)
Accepted by mtitoo@archer.com
You cannot set the Sample Point property directly. Instead, you should write the hexadecimal value from the custom baud rate dialog to the FDBaudRate property. See How Can I Set Custom Baud Rates on NI-XNET Devices?
https://tmesystems.net/
(823 Views)
Great!
(788 Views)
