VeriStand
How to monitor the actual model loop rate
HI,
Am using 3 different dlls added to the veristand. I want to monitor at which rate the model actually executes. Is there any way to monitor the model loop rate of individual dlls.
-Sid
(5,641 Views)
hello,
thanks you for posting on National Instruments Forum,
you can use the decimation control to set the model rate to be a decimation of the main loop rate. For example, if your primary control loop is at 200Hz and the decimation of the model is 2, the model will run at 100Hz. This is useful if you have multiple models you want to run at different rates. Just import them and change their decimation.
Brice S.
National Instruments France
(5,592 Views)
