VeriStand
How to read/write data from PXI digital channel to NI VeriStand 2017
I have defined and configured digital channels of PXI chassis in VeriStand 2017 system definition
file.
Now I need to read/write data from my circuit board via PXI digital channels into VeriStand PC.
Can some one tell me how to procedure further ?
By using Stimulus Profile Editor do I need to create sequence scripts for data acquisition?
(2,508 Views)
Some questions to understand what you want to achieve:
1. What kind of digital hardware do you use?
2. What timing do you want to achieve?
3. How many channels do you want to use for Read/Write?
4. What do you generally want to achieve here? In case if you want to feed the model with the data from digital channels, here may be some helpful steps to follow: http://zone.ni.com/reference/en-XX/help/372846H-01/veristand/mapping_channels/
For basic monitoring you can use simply the Workspace Editor or Channel Data Viewer.
Best Regards,
TK
Certified LabVIEW Architect (CLA)
(2,421 Views)
