VeriStand
VS2016 Iron Python on windows 7 to access hardware XNET-DAQ-FPGA
Hello I wrote a simple code to access hardware CAN channel from chassis using Ironpython Workspace2 SetsingleChannel method. I ran into an exception : Unexpected Exception Consult NI VeriStand help for error code 0xfffb4e32 error m essage Could not find channel 'Targets\Controller\Hardware\Chassis\DAQ\PXI1Slot2 It seems I am not able to access XNET port using IronPython. Please see my implementation below: APPDATADIR = r"C:\Users\Public\Documents\National Instruments\NI VeriStand 2016" CANPROJECTDIR = APPDATADIR + '\\Projects\TestPWM' CANSDF = CANPROJECTDIR + '\\TestPWM.nivssdf' print CANSDF LOGGINGDIR = CANPROJECTDIR + '\\Logs' TIMECHAN = 'Targets/Controller/System Channels/System Time' CANCHAN = 'Targets/Controller/Hardware/Chassis/NI-XNET/CAN/CAN1/Outgoing/Cyclic Event/BodyInfo_HS3 (946)/Ignition_Status' DIOCHANNEL = "Targets\Controller\Hardware\Chassis\DAQ\PXI1Slot2\Digital Output\port0\DO7" print CANCHAN print "Before Veristand Workspace Open" wks = NIVeriStand.Workspace2("localhost") print "After Veristand Open" try: print "Running %s" % CANSDF print "Inside System Definition File" wks.ConnectToSystem(CANSDF,1,60000) print "after Connect to system" print "NI VeriStand Running and Client Connected!" CanVal = wks.SetSingleChannelValue(CANCHAN,4) print "Ignition sent" while (state == 2): CanVal = wks.SetChannelValues(CANCHAN,4) print "If Veristand is open send ignition " time.sleep(1) raw_input("\n\nPress the enter key to exit.") except NIVeriStandException, e: TEST_COMMENT = "Unexpected Exception " + e.message() print TEST_COMMENT time.sleep(10) except: print sys.exc_info() time.sleep(10) finally: wks.DisconnectFromSystem("",1) Can anyone please suggest me how to access hardware ->Chassis->CAN or DAQ or FPGA using Veristand and Ironpython ?
Message 1 of 1
(2,423 Views)
