VeriStand
Implementing Linux ProfiBUS custom device in Veristand 2023
I am trying to implement the custom device for using ProfiBus KunBus DF Profi II card on a PXIe running Linux and LVRT 2023 and using Veristand 2023. Our previous version was a Pharlap PXI running LVRT 2019 and Veristand 2019.  Would anyone have the configuration and engine files needed to implement this?
I am getting the error: 307603 when I try to load the Custom Device into VS. I have built the project in a different directory than where Veristand is calling from and moved the files. Any suggestions would be greatly appreciated. Thank you.
(330 Views)
See Creating or Migrating a Linux_64 64-Bit VeriStand 2021 Custom Device LabVIEW Project
I am not familiar with the driver for Profibus. If the driver API is calling a DLL underlying, you would need to reach out to the original driver developer for the Linux SO shared library.
https://tmesystems.net/
(314 Views)
