11-16-2015 06:27 PM
11-17-2015
05:01 PM
- last edited on
10-09-2025
08:28 AM
by
Content Cleaner
You can find an example of programmatically FTPing in this KnowledgeBase.
11-18-2015 02:06 AM
11-19-2015 01:02 PM
Are you using NI-CAN or the NI-XNET driver? I usually expect ncl files to be associated with NI-CAN applications. This document can give you some more information about how to intereact with .ncl files.
11-19-2015 06:39 PM
11-20-2015 01:31 PM
NCL files are binary files so they will not be human readable. What data are you trying to pull out from them? Depending on what you are trying to extract you may be able to use the specifications in the document I linked in my last post. An alternate option is logging to a TDMS file. Finally, since you are using VeriStand you may be able to use this add-on in order to interpret the files.
Do you think any of these would suit your needs?
10-21-2022 10:47 AM
Hi @blackburnite
I would be interested in the logger for CAN to mf4/asc.
Would it be possible to the the custom device?
Best regards
10-21-2022 11:11 AM
I can look to see if I still have that code, but I haven't used it essentially since 2015 so no promises and for sure it will be an "as is" code drop. I can't support it much.
08-22-2025 11:14 AM
Hi, Is it possible to shared the code? Or Could you please explain how you have edited the existing data logger CD?
08-25-2025 01:18 AM
You can run NI-XNET Bus Monitor on the host PC while VeriStand is running. No custom device is needed.
Log Bus Traffic with NI-XNET Bus Monitor While Running NI-XNET Application
