VeriStand
Is there any support for cRIO CAN modules in VeriStand?
I wonder if there is any support (e.g. FPGA personalities) for Compact-RIO CAN modules (i.e. NI 9853) in VeriStand?
Regards
Martin
(6,968 Views)
Martin,
NI VeriStand R&D has not created an FPGA personality that supports the cRIO CAN module. As of my knowledge nobody at NI has created one so far.
At some point in the future NI will release a cRIO XNET module that will be supported by the XNET feature that has been introduced in NI VeriStand 2010.
Tom
(6,965 Views)
In the meantime the cRIO XNET module has been released. So now Veristand supports all XNET features on cRIO. Be aware that LV FPGA module is needed.
Andreas Stark
LabVIEW Lead @ Rocket Factory Augsburg
(6,421 Views)
In addition to NI VeriStand supporting the 986x series of XNET CAN modules, the XCP and CCP master add-on for NI VeriStand will work with the 985x modules if you're doing XCP or CCP
Stephen B
(6,403 Views)
