VeriStand
Veristand query
I am trying to log data continuously in NI Veristand. So i will be needing to disable the Data logging with Stimulus Profile Editor since I would use the Embedded Data Logger to log the data instead.  Is it possible to disable the Data logging with Stimulus Profile Editor when the stimulus profiles are running? .
(5,618 Views)
Do want the Stimulus Profile Editor to log at all?
If not, just don't set up any logging in the tool. Otherwise, you can use the Trigger Settings to help determine when to log and when not to log.
Cheers,
Olivia
(5,561 Views)
