VeriStand
Logging a NON RT channel
Hi am using a RT Chassis with pxi where my application also needs a USB DAQ. I need to record the NONRT channel value with RT channel data.I thought of a way to"Read channels from labview, write it to the some userchannels using API where i can select the user channel as a logging parameter in stimulus profile Editor.Is this the right way or Is there any better way to log the NON RT channels while executing the Profiles.
-SID
(5,956 Views)
It depends heavily on how you will be acquiring the data from the USB DAQ. Are you doing a buffered measurement at a higher rate than the control loop rate of VeriStand? If so, I presume you'd be doing so through a custom device of some sort?
Jarrod S.
(5,920 Views)
It will be at rate of 1kHz where am planning to set my PCL @ 5kHz.And also am planning to log the data through profiles at the rate of 100 to 1000 Hz
-Sid
(5,919 Views)
