VeriStand
NI-XNET (Hex 0xBFF6309A) Different Cluster Settings
I updated NI-XNET on my system and the rt target and now i get this error:
Pible reason(s):
NI-XNET:  (Hex 0xBFF6309A) The interface has already been opened with different cluster settings than the ones specified for this session. Solution: make sure that the cluster settings agree for the interface, or use a different interface.
(9,557 Views)
I tried removing and re-adding my XNET databases as well as re-deploying with veristand.
(9,556 Views)
Accepted by topic author MPCC
MPCC,
Can you click on the CAN Port in the System Definition and make sure the Cluster settings were maintained?  I've seen this option get reset before.
(9,548 Views)
OK So I tried that. The X-NET Database section was empty. So I corrected it with the proper X-NET Database.
I verified that the CAN Cluster is accurate to the CAN Cluster in the databases. Then, I tried to redeploy with no luck. I am still getting the same error.
Now that I am heading down this path, I just updated to NI-XNET 1.4. Is it possible that a setting somewhere else got hosed when I updated?
(9,542 Views)
It was a baud rate issue.
I had the wrong rate set up.It must have gotten reset with the other settings.
Thank you!
(9,529 Views)
