VeriStand
Mapping (so close ...)
No problem
This is my VI, could you test if you have the same matter ?
Thanks a lot !
Message 11 of 14
(2,140 Views)
Your code works on my side. The only trap is if the nivssdf file is not accessible and you don't look at the error cluster you won't see anything but the led remaining off.
the form of the channel names are i.e.: "Targets/Controller/Hardware/Chassis/DAQ/PXI1Slot3/Analog Output/AO0"
Message 12 of 14
(2,132 Views)
Ok I've finally find the problem. When I add some stuff in my Veristand project, I never completly close it ... To add the map, you must close Veristand. Again a dumb error. Thanks for your giving me the solution !
Now I try to add the map from a txt file. I think I'm not far to get the solution, could you take a lokk on this ?
Many thanks thumble  !
Message 13 of 14
(2,122 Views)
Accepted by topic author Nicopsa
Message 14 of 14
(2,085 Views)
