VeriStand
Multiple versions of Veristand.
I know that I can have multiple versions of LabVIEW and TestStand on the same PC.
Can I install multiple versions of Veristand on the same computer? As long as I am not running them at the same time is this possible?
John O'C
Staff Test Systems Engineer
Woodward, Inc.
Skokie, Illinois, USA
"Life is not a journey to the grave with the intention of arriving safely
in a pretty and well preserved body, but rather to skid in broadside,
thoroughly used up, totally worn out, and loudly proclaiming...
Wow...What a Ride!"
(1,377 Views)
Accepted by johnoc
Yes, I always had multiple versions of VeriStand installed to build custom devices. However, you can only run one version of VeriStand at a time.
https://tmesystems.net/
(1,358 Views)
Thank you for the information and the quick response!
John O'C
Woodward, Inc.
Wow...What a Ride!"
(1,345 Views)
Each version of VeriStand installs and runs a different version of DAQmx.  How do you deal with this issue and get around this mess?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LZTSA2&l=en-US
(1,071 Views)
VeriStand is dependent on LabVIEW and hence shares the same compatibility with LabVIEW. As a rule of thumb, NI drivers are backward-compatible to four versions of LabVIEW. Thus NI-DAQmx 2025 supports VeriStand 2025, 2024 and 2023 (there was no VeriStand 2022).
Edit:
Just realized the following.
Starting with LabVIEW 2022Q3 release, select NI drivers and toolkits will become version-independent from LabVIEW release. Extending Compatibility Between LabVIEW and NI Drivers with Addon Support
Hence, NI-DAQmx 2022 Q3 supports VeriStand 2023 or later (because VeriStand 2022 does not exist).
(1,050 Views)
Edit:
Instead of reading about what should work, I suggest trying it.  The process is a mess.
(1,017 Views)
