VeriStand
NI VeriStand not found on the tools
Hello everybody,
I'd like to create  a model to run it in veristand from a VI but the problem is, that i can't find NI VeriStand on the tools, i'm working with Labview 2011 and NI VeriStand 2012, It's probably the problem with the compatibility. I have installed the NI Veristand 2012  already and i can work with it but directly from the VeriStand Icon, and from the VI it's not possible.
Could be that may be working with VeriStand 2011? or should i configure it.
I have today installed the Labview 2012 as Evaluation and i still unfortunately can't find the VeriStand on the tools
I hope i explain the problem good and you can understand the situation
Thanks for your help
Josef
(5,595 Views)
You are correct in your assumption. VeriStand only supports one version of LabVIEW. VeriStand 2012 only supports LabVIEW 2012.
Jarrod S.
(5,593 Views)
