VeriStand
LabVIEW RT run-time license and VeriStand
There is something I would like to clarify.
Does the full development license of VeriStand include a LabVIEW RT run-time license ?
For example, If I plan to execute VeriStand on a Desktop PC turned into an RT target, do I need (as usual) to buy a run-time license for LabVIEW RT or this run-time license is already included in the VeriStand package ?
I think we have to buy a run-time license in every case, do you confirm ?
Thanks for your answer, have a nice day.
Da Helmut
Voir le profil de Maxime M. sur LinkedIn - View Maxime M.'s profile on LinkedIn
(6,793 Views)
Hi DaHelmut,
There is no LabVIEW RT runtime license; there is however a LabVIEW RT module license. However, in general NI VeriStand 2012 and earlier do not license any other NI product. If you are testing your VeriStand system on a Windows host, and then make a simple change of the controller to RT, then this should work fine with your NIVS Full Development license. If you do indeed have custom devices targeting RT devices, then in such case you will need the LabVIEW RT module and therefore its license.
Nestor
(6,763 Views)
Hi Nestor,
Thanks for your answers.
So what is this : https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019SIeSAM&l=en-US ?
And this : https://www.ni.com/en-us/shop/product/labview-real-time-module.html ?
Da Helmut
(6,752 Views)
http://sine.ni.com/nips/cds/view/p/lang/cs/nid/207294
781172-35 Contains PROOF OF PURCHASE OF REAL-TIME LICENSE FOR THE NI VERISTAND REAL-TIME ENGINE.
Jiri
CLA, CTA
(6,723 Views)
Accepted by topic author DaHelmut
After speaking with the appropriate people, I can confirm that the Full Dev and Operator licenses do indeed grant a LV RT Runtime license (one per NIVS license). The PC Dev license however does not.
Pardon any confusion Da Helmut.
Nestor
(6,702 Views)
