VeriStand
NI-XNET Custom Device for NI VeriStand
Hello, I am using the XNET custom device 1.5 for VeriStand 2009. After adding some incoming CAN messages, I received the error -10743848478 indicating that the max number of frames has been exceeded. What is the maximum number of frames, and is this directly related to the number of CAN messages or individual signals/channels I am trying to handle?
Thanks.
Message 21 of 24
(3,443 Views)
Hi, I am using the XNET custom device for 2009. Recently, the deployment of a database stalled so I had to abort the deployment and try again. Upon doing so, I received the attached error about the database cache file being too old: 0xBFF63147/-1074384569. I don't recall changing anything on the database or the XNET drivers. Thanks.
Message 22 of 24
(3,293 Views)
Hi hyog,
This same issue is discussed here: Error 1074384569 in NI Veristand Custom Device while deplying code. Once you have matching versions of XNET, everything should work fine.
Jayme W.
Message 23 of 24
(3,268 Views)
Hi, this is strange because I do have matching versions, and I even reinstalled VeriStand and XNET on the target and got no improvement. I ended up reformatting the target, and everything was OK after that.
Message 24 of 24
(3,266 Views)
