VeriStand
Need help to with my hardware configuration in VeriStand for the FPGA and CAN interface
Hi eveyone,
I have a PXI system with a PXIe-6738 analog output, PXIe-7820 R Digital I/O and a PXI-8512 CAN Interface.
I am able to add the hardware in my Chassis with VeriStand. But I receive 2 errors (-307832 and – 307826) I like to fix those error so I can continue with my work.
I receive error -307832 because my FPGA needs a .fpgaconfig file but I cannot find the correct .fpgaconfig file. In the folder “C:\Users\Public\Documents\National Instruments\NI VeriStand 2016\FPGA” are some .fpgaconfig with .lvbitx files but not for the FPGA I have. Does someone know where I can find the correct .fpgaconfig file with the .lvbitx?
Error -307826 is given by the CAN interface I probably have to add a Bitfile in the tab 986x Support. But I cannot find this file. Does someone know where I can find this?
Thank for the help.
Bart
(3,410 Views)
Hi Bart,
I have responded to your Service Request you have send in. Please let me know if you have any additional questions.
Maarten E
TSE
(3,364 Views)
Hello, I encountered the same problem as you. How did you solve it before?
(2,397 Views)
(2,392 Views)
