VeriStand
print console PXI 8880
With the controller PXIe-8880 there is no option under MAX to activate console output.  Therefore no msg will be printed when you use a fonction like RT Debug string, Print debug String....
To activate the console, you have to type this line in putty
nirtcfg --set section=SYSTEMSETTINGS,token=ConsoleOut.enabled,value=True
Message 1 of 1
(1,392 Views)
