VeriStand
lvmodel error when run it in veristand
I build a model with labview and compiled it into lvmodel file.
after I run the veristand project , something strange happened.
I donot know why , may I am lack of deep comprehension of the veristand's run strategy.
Can anyone explain for me the reason ? great thanks...
(2,185 Views)
I think this is an expected behavior.
NI VeriStand writes zero to "in1" but no one writes the result into NI VeriStand.
As the result, NI VeriStand engine keeps "in1" zero.
Certified LabVIEW Developer
GCentral
(2,159 Views)
Accepted by topic author alii001
your inport is always being overwritten by the value that is being written to the inport on each iteration i.e. 0, if you set your inport to another number eg. 1 or 2 or 10, etc. then it would stay that value
the ability to overwrite inports does not exist for models it does however exist for custom devices by getting a channel reference to your custom device input with write permission and setting it that way so you could achieve this with an inline model custom device
(2,129 Views)
How? it is just a model, and these two icons are all indicators, how can Veristand change the value of "In1"?
(2,071 Views)
yes, this may be the reason , models' inputs in veristand shall not be written by the model itself , except for such custom devices
(2,070 Views)
yep thats the deal
(2,029 Views)
