VeriStand
Ni Veristand Crash while disconnecting from PXIe-8133 controller.
My Veristand crashes when I try to disconnect my laptop from the Controller. It always does that when I try to disconnect it. It also stops responding when I try to undeply the code from the controller.
Would be great if someone could help me out here.
Thanks.
Vishwa.
I have NI Veristand 2011 SP1
Win 7 32 bit.
LabView 2011 SP1
(5,749 Views)
You might check Update Service to see if there any patches available to apply for the LabVIEW 2011 SP1 run-time engine. There was a specific fix in the LabVIEW 2011 SP1 f2 patch that addressed a known issue that caused VeriStand 2011 SP1 to crash when undeploying or disconnecting.
You can also check in MAX under the Software section what version of the LabVIEW 2011 SP1 run-time engine you have installed.
Jarrod S.
(5,739 Views)
