VeriStand
Sequence Code for Multi-Task to occur at specified cycle count(s)
I have a test where I need to break out of a task into another task at a predefined number of cycles.  I using a Stimulus Profile Sequence to control the tasks.  I need to break out from the task every 150 cycles and am using a For Loop for this.  In addition, I need to break out every 500 cycles for different task.  Then come back into my original Task.
I can't quite figure how to wrap a For Loop inside another For Loop for this event.  I have created a cycle counter and have tried a If Else where I specify the cycle count where to break out for the task, but I would think there is a better way to handle this for a high cycle count test.  Should I create a Variable that becomes true when the Cycle Count is a multiple of 500?  How would I go about this?
Thank you.
(5,996 Views)
What exactly do you mean by break out of a task into another task? Do you want to suspend one operation and start another at regular intervals?
Jarrod S.
(5,983 Views)
Jarrod,
That is correct.
Thank you.
(5,971 Views)
A very helpful reference is the tutorial Getting Started with Stimulus Profiles in NI VeriStand.  Specifically, it seems that the functionality you are looking for could be achieved with more conditional statements, so check out Example 2 in the Tutorial.
Best,
Ryan C.
(5,937 Views)
