VeriStand
Problem deploying Veristand project to cRIO-9057
I am using for the first time Veristand and I am encountering a problem in deploying a Veristand project into a cRIO-9057.
In the project I am simply importing an external FMU (I am using the Engine Demo 64.so from NI) and using a Conditional block to generate a digital output (NI cRIO 9474 module is installed with the cRIO).
When I try to deploy the model, the following error is returned by Veristand:
However, if from the System Explorer I disable the NI cRIO 9474 module in the System Definition File, then the project is correctly deployed and the model works fine. So I am thinking that there may be some compatibility issues of the DAQmx drivers, but I cannot figure out why...
I attach the following pictures:
- Project_screen, which is a screenshoot of the project
- cRIO9057_sofware, screenshot of the software packages currently installed on the RT target
The Veristand version I am currently using is the 2023Q4, while the NI DAQmx drivers version installed on the host computer is the 2023Q4 as well.
Thanks to anyone who will try to help!
LukeB
(663 Views)
Accepted by topic author LukeB91
Your VeriStand version on the host PC is 2023 Q4, but the VeriStand Engine installed on the cRIO is 20.6
https://tmesystems.net/
(648 Views)
