VeriStand
Programmatically adding VS custom device
hello Stephen B
I can understand what you said up, but I have no diea about
"you can actually call the initialization VI if you want. To do that, get the NodeID from the CustomDevice object and pass that to the connector pane of the initialization VI."
Can you make an example or detail it again, Thank you!
Message 11 of 11
(3,182 Views)
