VeriStand
Programmatically updating custom scales
Is it possible to programmatically update custom scales after the project has been deployed?
I'm working on a custom calibration routine using VeriStand as a back end HAL.  We regularly do flow meters which use a lookup table as a custom scale. After calibration, this lookup table is going to change, so this needs to be done programmatically.  Unfortunately, I have found nothing in the API, and Google returns either a bunch of results about custom devices or about doing it with a DAQmx task.  The only other option I can think of is finding the table in the system definition file and undeploying / redeploying the project to force updates to happen on the RT target.  This seems... a poor choice.
-M
(3,994 Views)
You will have to undeploy and redeploy if you need to update the LUT. However if you can live with the original LUT plus a polynomial on top, you can use the calibration API or GUI
Stephen B
(3,976 Views)
I figured that would be the case. No, I'm doing a polynomial on top as the calibration, but both are required.
(3,971 Views)
