VeriStand
no “NIVeristand.tlc” in simulink code generaion
I  downloaded the VeriStand 2015.and install all the items
Then I learned "creating simulantion models using the mathworks simulink in NI VeriStand" in URL http://www.ni.com/tutorial/13066/en/
but I do not get the option 'NIVeriStand.tlc' of the simulink code generation\system target file
I do not know the reason, Help me pls,thank you!
(4,177 Views)
Now,I found the reason:
this Veristand 2015 is evaluation version.I downloaded and installed this version[ https://www.ni.com/en/support/downloads/software-products/download.veristand.html#313354  ] just now,and the problem solved
(4,163 Views)
