VeriStand
Reading multiple analog channels in custom device
I am using Veristand 2011 together with a PXIe-8108 controller and PXIe-6363 IO.
I have created a custom device and in this custom device, I need to read values from multiple analog channels.
I am using the standard way, creating a task, assigning channels, starting the task and reading the values.
This works as long as I read only a single channel.
When I read multiple channels, the application does not start, but shows Error 1026, VI Reference is invalid.
When I use the code from the custom device that handles the analog input, in a plain LabVIEW RT projects, I can read multiple channels.
Does anybody know, if the Analog 1D DBL  NChan 1Samp instance of the Daqmx Read VI is supported in Veristand custom devices?
Christian
(5,779 Views)
There is a labview bug, fixed in 2012, that causes this. The work around is to save your own copy of that daqmx read Vi
Stephen B
(5,772 Views)
Thank you, I will check this out.
(5,768 Views)
