VeriStand
Real Time Stimulus Error -307662 (Node is not found in the system.)
I am controlling a test bench using 2 cRIO chassis (cRIO9074 and cRIO9024+cRIO9118). I can control the bench wrom workspace.
I am having trouble with Real Time Stimulus. I am getting Error -307662 (Node is not found in the system.). I can control two chassis on one stimulus profile before.
It seems like stimulus profile edittor generating random errors. Because the functions that I used is working before.
Best Regards,
Hreidmar
(7,591 Views)
Here I have attached the stimulus profile file, sequences and stimulus execution result xml report.
Best Regards,
Hrteidmar,
(7,587 Views)
I have figured out the problem. The root of the problem is me. Smiley Wink
If Evaluation Method equals to ByValue, Default Assignment Field left blak for scalar values or connected to a real channel.
Best Regards,
Hreidmar
(7,583 Views)
