VeriStand
Run Multiple Projects Simultaneously on one host PC
If, for example, I have two independent VeriStand projects each with its own real-time target can I run both projects while maintaining a connection to both (via the VeriStand API in LabVIEW) using a single Windows Desktop PC?
LabVIEW/VeriStand 2013 SP1 (to be upgraded soon to 2017 or newer).
(4,046 Views)
Accepted by NathanJD
Nathan,
Currently only one instance of the VeriStand Gateway can run on a Windows PC host. The Gateway can only communicate to multiple real-time targets if they are in the same VeriStand System Definition.
It is possible to silently disconnect/connect the Gateway to switch communication between different real-time targets, but the Gateway can only exchange data with one target at a time unless they are in the same project/sys def.
Another option may be to use a separate virtual machine to handle each VeriStand project. This would be two separate Windows environments but you could use a single physical PC.
I hope that helps!
Andy
(4,018 Views)
Thanks for the explanation.  I was thinking that this would be the answer but wanted to see if it was indeed the case.
(4,012 Views)
