VeriStand
Sending Raw CAN through Veristand XNET
I am new to Veristand and can we send raw CAN messages using NI Veristand XNET?
Pankaj
(3,439 Views)
Hello Pankaj,
Yes you can use XNET to send CAN messages in VeriStand. Take a look at the Getting Started Guide below.
Getting Started with NI-XNET for NI VeriStand and NI LabVIEW
http://www.ni.com/tutorial/14706/en/
Jared T.
(3,412 Views)
Hello all,
 However it's not directly possible to send raw (i.e. not defined in a DBC file) messages (unless new Veristand has such a feature). For this we needed to develop a Custom Device (we're on NIVS 2016).
Piotr F.
Hardware Engineer @ ZF
(3,400 Views)
Hi all,
do you know if exist  a "raw can custom device" or an example from which start
I tried to check on-line without success...thanks!
(3,328 Views)
Hi zundap1970,
 You could start from this: https://github.com/NIVeriStandAdd-Ons/XNET-CAN-Bus-Monitor-Custom-Device. It has some redundant code for this use case, but works.
Piotr F.
(3,323 Views)
