VeriStand
TDMS channel size
I build a channel to measure ECU output, the max timestamp =18500ms,  logging file setting rate=250Hz. At first I think Veristand can output 4625(18.58250=4625) data   in the TDMS file. But in fact  the channel length is 4832 inthe  TDMS file after finished runing.
Allen Liu
Lear CTC
Email: rliu01@lear.com
(5,896 Views)
Which API you used to log your datas?
The size is it due maybe to a flush buffer.
How your datalogging is configured?
R.kaszubiak
(5,441 Views)
