VeriStand
Target is disconnected, but my target is the host computer I'm on
Glad to know the workaround helps!
I would not really know what could have happened. Theoretically, if there was no software installed as you mentioned, nothing should have changed (maybe an automatic update).
Something you could eventually try if you want to try solving the issue for good could be force reinstalling VeriStand. The procedure is more thorough than repairing or a normal uninstall/reinstall so it could help.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGwJCAW&l=en-US
You will need to run the NI-DAQmx installer after the reinstallation because VeriStand will be fresh so it won't have the driver support.
Camilo V.
Message 21 of 22
(1,072 Views)
120000 ms is the default value - so nothing would have been changed. My guess is that this particular computer experiencing timeouts is busy with enough other activity that it resulted in a slower-than-typical deployment of your projects. Is there some other resource-intensive process on your machine that isn't present or running on your other machines that don't exhibit this timeout?
In any case, great to hear you are up and running!
Message 22 of 22
(1,069 Views)
