VeriStand
The Inertia plug-in for Veristand (2016)
Is there any documentation on the Inertia software that runs on VeriStand? I am attempting to create an Inertia calculation that will determine if the inertia controller is being activated by monitoring "Mode Status". Unfortunately, I don't know what values "Mode Status" kicks out. For example, 0 for inactive and 1 for active. Any help would be greatly appreciated.
-Scott
(17,193 Views)
Which Inertia software you are using specifically?
https://tmesystems.net/
(17,163 Views)
It's Inertia 2016. I don't know if there are different plug-ins, but this software gives us the ability to run PID on selected outputs and allows for the creation of scripts for automating processes as well. The picture shows what I am referring to.Inertia.jpg
(17,156 Views)
INERTIA Add-On for VeriStand  is developed and maintained by Genuen. I would recommend reaching out to them directly.
(17,147 Views)
Accepted by topic author ScottSanville
Just in case anyone comes across this and is interested...
Below is what the numbers mean in terms of status.
0 = PID Mode Disabled
1 = PID Mode Active and Running Test Profile
2 = PID Mode Active in Manual Control
They still haven't told me where they found this info; it wasn't in the help file from what I could tell.
(17,136 Views)
