VeriStand
Triggering multiple, synchronized logging sessions from LabVIEW
Using Veristrand 2020 R6, LabVIEW 2020, we are building a VI to log data from Veristand to TDMS on the Host PC. The user can organize the data to be saved in groups and select a different logging rate for each channel group. This means starting separate logging sessions for each logging rate.
The question I have is about triggering all these sessions to start simultaneously, so the data is synchronized (to within 1 period) in the file.
At the moment, we are using a digital edge trigger on a dedicated User Channel to start the sessions. This works pretty well but I'm not 100% happy with the fact that this user channel has to be created (with the correct path) on each application to be able to use this logging VI. Also, I'm a little concerned about using the same trigger channel to start several logfiles (in parallel).
Any tips or tricks are welcome.
PJ
(1,902 Views)
Heya,
So as I understood you are trying to create a trigger in LabVIEW to trigger multiple channels in VeriStand: have you seen this KB: Easily Synchronize and Trigger NI-DAQmx with Channel Expansion
If this is not useful, please elaborate on the requirement.
(1,855 Views)
I have the same desire to trigger a Veristand logging session from LabVIEW - without the need for additional user channels. So far I have not been successful.
In digging through the .net Veristand Client API, I found some functions related to triggers, but it seems they are only related to trigger configuration rather than direct triggering.
Would love to hear if you ever got this working!
(998 Views)
