VeriStand
Veristand2015 not support CAN FD?
I configure a database as CAN FD setting in the XNET DataBase Editor as pic1;
When add the can port 3 using this can cluster,the Veristand UI only show one Baudrate setting as pic2;
Besides,pic3 is my components information.
After that,i deploy the files the error report as:
Possible reason(s):
NI-XNET: (Hex 0xBFF6309A) The interface has already been opened with different cluster settings than the ones specified for this session. Solution: make sure that the cluster settings agree for the interface, or use a different interface.
NI VeriStand: NI VeriStand Engine.lvlib:VeriStand Engine Wrapper (RT).vi >> NI VeriStand Engine.lvlib:VeriStand Engine.vi >> NI VeriStand Engine.lvlib:VeriStand Engine State Machine.vi >> NI VeriStand Engine.lvlib:Initialize Inline Custom Devices.vi >> Custom Devices Storage.lvlib:Initialize Device (HW Interface).vi
So,my question is:Are there any incompatible parts or components in my enviroment?
                                how can i make the can fd settings work?
(1,112 Views)
You can find most answers on ni.com
Does NI VeriStand Support CAN FD?
https://tmesystems.net/
(1,080 Views)
It seems Veristand2015 supports CANFD but the configuration is a little bit different from the 2019 or later,i still can not solve the problem
(951 Views)
What problem were you having? You need to provide a detailed statement of what you have done and what error or behavior you saw for us to provide a recommendation.
Before running VeriStand, have you tried to run NI-XNET Bus Monitor?
(937 Views)
Picture below is my database configuration
this one is CAN configuration in Veristand 
While running this project,the error messages showed as:
(886 Views)
Make sure all configured CAN sections are assigned a unique CAN port.
If you are running NI-XNET Bus Monitor at the same time, make sure the baud rate configuration is the same.
(871 Views)
