VeriStand
Use of scade in Veristand
I am currently evaluating the possibility of making different models for use in Veristand. I would like to know how to import models from Esterel Scade and NI Multisim (if possible) in Veristand.
What are the files extensions used ? I am asking this because when we try to import a model in Veristand, it only looks for *.dll, *.lvmodel, *.mdl and *.out files.
Thank you,
Maxime
(6,353 Views)
Hello MaximeD,
Thanks for posting here.
Here some links which should give you some answers :
In the help of NI VeriStand, you can read which environments allow to create supported models for VeriStand : NI VeriStand™ Help
You also can refer to this following document : Using Simulation Models with NI VeriStand
The supported file formats are .dll, .mdl or .lvmodel.
Jérémy C.
NI France
(6,332 Views)
Thank you for your answer.
Does anyone had any experience making a model with scade for use in Veristand ? I also wanted to know if it was possible to directly build a .dll, .mdl or .lvmodel directly from scade.
Thanks in advance for your help,
Maxime
(6,316 Views)
Accepted by topic author MaximeD
From SCADE you can generate DLLs that work with NI VeriStand. Contact Esterel to get all the details
Stephen B
(6,305 Views)
