VeriStand
Using PXIe-6612 card for Pulse measurement in Veristand
Hello Friends/members
I got to know that we cannot use the PXIe-6612 card for Pulse measurement in Veristand. And Only X Series Card support Pulse Measurement. Any of you have update about the same ? from the Below description it is clearly mentioned that it can Measure Period , Pulse-Width and Frequency.
PXIe-6612 : PXI Counter/Timer Module
PXIe, 5 V, 8-Channel PXI Counter/Timer Module—The PXIe‑6612 performs encoder position measurement, event counting, period measurement, pulse-width measurement, pulse generation, pulse-train generation, and frequency measurement. It features eight counter/timers, digital debouncing filters, and TTL/CMOS‑compatible digital I/O
Regards
Kiran
(1,992 Views)
Accepted by KiranKeshavegowda
Got the Feedback from NI saying , Only X Series DAQ devices support pulse measurement and PXIe 6612 card cannot be used for Pulse measurement in  Veristand.
(1,944 Views)
Yes, you cannot use pulse measurement function in Veristand, but semi period mesuremet function returns same result to us. Semi period mesurement function returns back high semi period and low semi period values in seconds. You can prepare custom device with this function.
(1,840 Views)
