VeriStand
VeriStand and cRIO HW
I'm an experienced LV developer starting to investigate VeriStand.  I'm interested in running on RT for the deterministic behavior.
Is there a document that discusses which cRIO controller/chassis are compatible with VeriStand and the advantages/disadvantages each might have?
A few specifics; I'm interested in 8-slot systems.  I anticipate using various AI modules (load, voltage, thermocouples), AO signals, DI, DO, Encoders, CAN/LIN (via XNet).
(384 Views)
Any Crio are compatible , do you have material course you follow and read?
CLA
(374 Views)
Ahmed99,
Thanks for the response.
How would I go about gauging the difference (in terms of VeriStand capabilities/performance) of a cRIO-9045 and cRIO-9057?  Both have similar specs and price.
(356 Views)
