VeriStand
Veristand - Reading A2L file
Is it possible to read A2L files directly using Veristand on "System Explorer -> Hardware -> Add NI-CAN -> Messages -> Import NI-CAN Messages" ?
I saw that's possible to do it with .dbc or .ncd files, but we use .a2l file.
Any suggestion will be appreciated.
(10,460 Views)
I'm checking with NI Corporation if is possible to open this type of file within Veristand.
I'll let you know if this is possible any time they answer me.
Thanks.
Best Regards
Luciano Borges
Test Development Engineer
(10,446 Views)
VeriStand is not capable of directly reading A2L files. You might see if there is a 3rd-party converter that can create a dbc or ncd file.
Jarrod S.
(10,442 Views)
Accepted by letreca
I've contacted Luciano with some options, he should get in contact with you soon.
Take care,
Stephen B
(10,408 Views)
Hi Stephen,
I talked to Luciano last week and these options solved our problem.
Thank you very much.
Robson
(10,383 Views)
Now that this is available on the web, here is the link: XCP and CCP Master Add-on for NI VeriStand http://zone.ni.com/devzone/cda/epd/p/id/6374 Take care,
Stephen B
(10,237 Views)
