VeriStand
Veristand Tutorial Installation: "No software will be installed"
I am trying to install the NI Veristand tutorial.  I have downloaded and extracted the *.zip file to my desktop.  When I run the setup program, it states "no software will be installed" on the second or third screen.
There are a few other forum discussions on this topic with other installers but none seem helpful.
Can anyone help? I would really like to use this tutorial.
Jordan
Jordan McBain, PhD
LabVIEW Controls Engineer
Revolutionary Engineering
(6,254 Views)
Hi Jordan,
I just downloaded the tutorial and it works just fine. I have the full version of Veristand on Windows 7.
Are you sure you are using the right version, the one XP or Windows 7 depending on your computer? Do you have the evaluation version or the full version of Veristand?
I don't know what else could cause problem.
PPrez
(6,246 Views)
Thanks for exploring this for me.
I have 32bit Windows 7 with a full-fledged version of NI Veristand 2011 (and NI professional developer suite).  I can successfully open and run models in Veristand.  I just can't even imagine what the problem is.
Jordan McBain, PhD
(6,244 Views)
Accepted by JordanJMcBain
Check that you don't already have the veristand hands on installed. The installers conflict. So you would need to uninstall that first
Stephen B
(6,238 Views)
Thank you
Jordan McBain, PhD
(6,226 Views)
