VeriStand
What Are the TCP/UDP Ports Used By VeriStand RT Engine?
Looking for information like this but for VeriStand RT engine
https://www.ni.com/en/support/security/configuring-software-and-hardware-firewalls-to-support-nation...
Stephen B
(6,282 Views)
The engine uses
  • TCP ports 2050 and 2040
  • UDP ports 56432, 56431, 56441
Do you have other things on the network that could be conflicting with these ports, or are you just building a list?
Cameron
(6,253 Views)
Accepted by StephenB
Full list
  1. UDP port 44525 – NI hardware configuration
  2. UDP port 5353 – mDNS
  3. TCP port 3580 – NI NAT-Service locator
  4. TCP port 80 – Web configuration and WebDAV file transfer
  5. TCP Port 51700 – CAN database deployment
  6. TCP Port 2040 & 2050 – VeriStand engine communication
  7. TCP Port 2039 – VeriStand gateway communication
  8. TCP Port 2041 – VeriStand project communication
  9. TCP port 2042 – Gateway transfer services
Stephen B
(6,200 Views)
